Date/Time: Sat, 19 Apr 2025 09:46:41 +0000
Scroll Bar for Control Bars?
View Count: 96
[2025-03-16 10:32:34]
User92573 - Posts: 559
Dear Support
Is there an option or possibility to add vertical scrolling to a control bar that will allow us to access buttons that may be out of sight given screen and/or orientation?
Many thanks
[2025-03-17 14:03:29]
John - SC Support - Posts: 39362
When a control bar is vertically oriented and some buttons are out of view, the "<" and ">" icons will be displayed to allow you to move the buttons up or down in order to view items that are not currently available.
Date Time Of Last Edit: 2025-03-17 14:03:58
[2025-03-18 09:12:01]
Hi John
I don't get any "<" and ">" icons on either computer when the toolbar extends out of range on my monitor.
Many thanks.
[2025-03-18 15:29:48]
It does not matter if it is extending out of range of the monitor. So if you have a floating Control Bar and it is longer than your monitor, then there is nothing that can be done in this case. This is typical Windows behavior - that items can be drawn beyond the edges of the monitor.
The "<" and ">" will show when the Control Bar is attached to a chart or the main window and that window is then not as tall as the Control Bar.
