Date/Time: Sat, 19 Apr 2025 09:42:45 +0000
Control bar customisation
View Count: 108
[2025-03-15 20:07:20] |
SafSaf - Posts: 126 |
is there a way to change the colour of a control bar button once it's clicked on so it shows your using the particular tool assigned to that button?
[2025-03-17 13:36:54] |
John - SC Support - Posts: 39362 |
There is not a way to set a separate color for when the button is depressed. The buttons do change to a "crosshatched" look to denote they are depressed.
[2025-03-17 20:02:03] |
my buttons don't turn into a crosshatched look. how do i get them to do that please?
[2025-03-17 21:08:27] |
Sorry - "crosshatched" was not the correct term (I was confusing myself with another system I worked on). The color is changed to a "lighter" version of what is set for the color to denote that the button is depressed. Keep in mind that this will only apply to buttons that have a toggle state, such as the selection for a drawing tool. If the button just performs an action, such as opening the "Find Symbol" window, then it will not have a "depressed" state so it will not change the color. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
