Date/Time: Sat, 19 Apr 2025 15:21:53 +0000
[User Discussion] - zigZag does NOT catch Inside day reversals!
View Count: 145
[2025-03-15 11:55:27] |
User360283 - Posts: 514 |
I've been using the ZigZag study for several months. It works OK for Daily New Highs and Lows But it does not signal reversals INSIDE the current day high low range. Is this a setting issue? What is the setting to include INSIDE day reversals Help please Thanks |
[2025-03-15 21:32:05] |
Sierra_Chart Engineering - Posts: 19276 |
This is not within the scope of our support.
[2025-03-17 03:06:12] |
Duh? Are you joking? I asked how to work on inside the day's high and low??? help please |
[2025-03-17 10:51:43] |
User431178 - Posts: 649 |
I asked how to work on inside the day's high and low??? help please You could always read the docs, all is explained in great detail. Zig Zag |
[2025-03-17 16:50:52] |
John - SC Support - Posts: 39362 |
What exactly do you mean by "What is the setting to include INSIDE day reversals"? The Zig Zag gives general indications of up or down swings in the data. You control how often those swings occur with the Inputs to the study. All of which is documented, in great detail, in the documentation for the study as given in the link above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
