Date/Time: Mon, 21 Apr 2025 04:41:27 +0000
Manage Drawing UI - 3 improvements - requested
View Count: 119
[2025-03-14 20:46:53] |
JohnR - User831573 - Posts: 330 |
1 - I frequently use the Manage Drawing window. Often, I want to delete multiple drawing. Many other windows let the user by default select multiple items. If you just want one, then just click on one. As part of that I would add a button on the bottom, for Select All. By doing those 2 things, you can now eliminate the Option in the menu structure. 2 - The ability to select the primary column to sort up/down 3 - Add a new column - Region the object is in. Thanks for your time to consider. JohnR |
[2025-03-16 02:29:06] |
Sierra_Chart Engineering - Posts: 19285 |
We will look some of this over. Sorting is very difficult, so not likely we would do that.
