Date/Time: Sat, 19 Apr 2025 15:21:51 +0000
Loss management - trade symbol vs chart symbol
View Count: 85
[2025-03-14 17:58:02] |
GreenAlien - Posts: 7 |
I noticed that when I trade MES from an ES chart, the loss management still calculates the loss value amount based on ES points. For example, if I set the loss limit to $300, taking a loss of 6 MES points locks me out for the day. I can get around this by making the $ value 10 times, but there is an issue with the calculation. |
[2025-03-14 19:45:22] |
John - SC Support - Posts: 39362 |
When using a "Trade and Current Quote Symbol" you need to adjust the "Currency Value per Tick" to be the value of the entered "Trade and Current Quote Symbol". Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
