Date/Time: Mon, 21 Apr 2025 04:50:12 +0000
Request for Smaller Increments in Price Display Format & Tick Size
View Count: 133
[2025-03-14 17:34:20]
ticinotrader - Posts: 411
Dear Support,
Could you please add the ability to use smaller increments/settings for Price Display Format and Tick Size in the Symbol settings? Currently, the lowest available option allows selecting up to 8 decimal places, but certain products (especially crypto) trade in even smaller increments (e.g., 9, 10, or 11, etc decimals).
I’m attaching a screenshot as an example—this is a crypto symbol from the BitMEX datafeed, which trades in 9-decimal increments, but the system currently only allows setting it to 8 decimals.
Would it be possible to extend this setting to accommodate these smaller increments?
Thanks in advance for your help!
image20250314_182246.png / V - Attached On 2025-03-14 17:32:23 UTC - Size: 297.04 KB - 32 views
[2025-03-14 22:31:58]
Sierra_Chart Engineering - Posts: 19285
No we are not going to do this. These small increments create problems. We are just not going to add this. We are not going to create more problems. It is simply out of the question.
Date Time Of Last Edit: 2025-03-14 22:32:10
