Date/Time: Sat, 19 Apr 2025 15:21:51 +0000
Numbers Bar Feature Request - Ask Vol Bid Vol Difference Text Left Aligned
View Count: 79
[2025-03-14 17:09:14] |
mastadom - Posts: 17 |
Hello Sierra Chart team, Can I make a feature request for the numbers bar study? For the Numbers Bars Text option, can you possible add the "Left" side aligned option for "Ask Vol Bid Vol Difference"? Currently, the default is Right aligned. Thank you |
[2025-03-14 17:18:44] |
John - SC Support - Posts: 39362 |
Refer to the following: Numbers Bars: Single Value Text Alignment For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
