Date/Time: Mon, 21 Apr 2025 13:14:38 +0000
What is the minimum OpenGL version for Sierra Chart?
View Count: 320
[2025-03-14 16:40:00]
User932063 - Posts: 10
Hi
What is the minimum OpenGL used by Sierra Chart?
I ask this because I'm trying to figure out virtualization in my trading environment.
Parallels and Crossover's OpenGL version is 4.1, which is passed directly from MacOS. However, VMWare Fusion's OpenGL version is emulated and it's 4.3.
It seems Sierra Chart detects OpenGL properly on VMWare Fusion only, so I was wondering if there's some kind of minimum OpenGL specification in place. I combed through the documentation but I have not seen anything regarding this.
I appreciate your help!
[2025-03-14 20:25:57]
I'm guessing this is just a OpenGL 4.1 vs 4.3 thing and that OpenGL 4.1 is unsupported, but I'm not 100% sure.
[2025-03-15 13:07:06]
User920967 - Posts: 63
Interesting question.
Have you ever been able to use "use openGL for chart graphics" while emulating on a mac?
I have attempted various times with different methods and never been successful (setting reverts back to unchecked after Sierra restart). Any insight shared would be greatly appreciated.
Best.
[2025-03-15 21:34:36]
Sierra_Chart Engineering - Posts: 19285
We are checking on this.
[2025-03-17 20:55:14]
OpenGL version 3.3 and higher is supported with Sierra Chart.
[2025-04-17 19:58:43]
That's quite strange. What are your thoughts as to why Sierra Chart does not detect OpenGL properly on Parallels? It works properly on VMWare Fusion.
- Do you know if there is any way to increase the level of logging to see whether OpenGL has been detected?
- Is it looking for a specific string for the version, or the GLSL version? If you could verify with engineering, I would appreciate it.
VMWare Fusion (this works) - https://gist.github.com/brettgoulder/2803d1710ca3a7f9f9eecff75924a409
Parallels 20 (this does not work) - https://gist.github.com/brettgoulder/ce448722269603329d741c4787f69e70
VMWare's GLSL version is 4.30
Parallel's GLSL version 4.10
I appreciate all your help!
[2025-04-17 22:48:49]
We will check on this.
[2025-04-18 05:15:40]
Install this utility here:
https://www.techpowerup.com/gpuz/
Provide screenshots, of the different tabs.
This is another utility: https://www.realtech-vr.com/home/?page_id=1402
Date Time Of Last Edit: 2025-04-18 05:33:21
