Date/Time: Sat, 19 Apr 2025 15:21:53 +0000
Custom order routing
View Count: 77
[2025-03-14 12:13:37]
User358514 - Posts: 11
Dear SC support,
Is it possible to catch the order related events from a study?
Or do you happened to have some kind of interface description what I could implement and select it from inside of SC to route the orders directly to that?
Thank you,
Balazs
[2025-03-14 14:11:06]
Sierra_Chart Engineering - Posts: 19276
A custom study can get data on existing orders but it is not designed to be catching order related events. So that is not exactly possible like that.
You can use the DTC Client in Sierra Chart and connect your own trading server:
Data and Trading Communications (DTC) Protocol Test Client
Date Time Of Last Edit: 2025-03-14 14:11:55
