Date/Time: Sat, 19 Apr 2025 15:21:55 +0000
Interactive Brokers Europe and lower CME fee
View Count: 102
[2025-03-14 08:45:47] |
User365411 - Posts: 193 |
European citizens that want to open an account with Interactive Broker are redirected to the Ireland affiliate site https://www.interactivebrokers.ie Do you know if opening an account with this entity it's possible to obtain reduced fee on CME? TY Date Time Of Last Edit: 2025-03-14 08:46:15
[2025-03-14 14:23:36] |
John - SC Support - Posts: 39362 |
We do not believe there would be any issue with this. The interface to Interactive Brokers should be the same regardless of the location. We certainly have never heard anyone say that it doesn't work, but we also cannot say that we have heard that it does. In the end, you would need to try and see if you can make the connection. To make a connection you would need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages You can change your package at any time, so you can change to try it and then change back. Refer to the following instructions: Sierra Chart Purchase and License Information: Changing Package To actually connect to Interactive Brokers, follow the instructions at the following link: Interactive Brokers Trading Service: Setup Instructions Make sure you are logging in to a live trading account, and not a paper account with Interactive Brokers. You can verify that the connection works for the CME Group Non-Professional verification by checking that the "Verified Until" date for your account updated to 30 days in the future when you make the connection. You can view this date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
