Date/Time: Sat, 19 Apr 2025 15:23:46 +0000
Showing a Single Diagonal Ask Volume - Bid Volume Difference in Volume Bars
View Count: 136
[2025-03-13 23:37:54] |
User871314 - Posts: 7 |
Hi, Is it possible for the Show Volume in Bars option on a Volume By Price profile to show only a single number representing the diagonal ask-bid volume difference? Right now the two options available show two numbers side by side as shown in the example below (each row represents a label for a bar). X|X X|X X|X Thanks |
Attachment Deleted. ![]() |
[2025-03-14 14:14:18] |
John - SC Support - Posts: 39362 |
There is no current support for this within the Volume by Price study. You could get what you want by using a Numbers Bars study and having an intraday chart set to the time frame you want. The Numbers Bars support displaying just one side of a diagonal difference. We have set this as a Feature Request. We take all requests, but we cannot say when we would get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
