Date/Time: Fri, 18 Apr 2025 06:42:34 +0000
[Programming Help] - End of day extension lines
View Count: 230
[2025-03-13 19:53:48] |
User664579 - Posts: 9 |
Hello, I was looking for an example of the ACSIL code to be able to add an option to extend line until end of the day similar to one of the options included in the Color Bar Based on alert condition study. I know that we can use functions sc.AddLineUntilFutureIntersection(), sc.AddLineUntilFutureIntersectionEx(), sc.DeleteLineUntilFutureIntersection() to use extend line until further intersection and this is very helpful. But I need also to be able to extend line until end of day and I have difficulties coding this. Is there an example somewhere I can look for? Or maybe someone who knows how to code this provide an example? Thank you in advance! |
[2025-03-24 20:45:33] |
Sierra_Chart Engineering - Posts: 19259 |
The closest we would recommend is to look at the source code of the Daily OHLC study. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
