Date/Time: Sat, 19 Apr 2025 15:25:55 +0000
Intergraph formulas
View Count: 78
[2025-03-13 19:30:06] |
JabDouks25 - Posts: 10 |
Hello, i would like to get informations from different graphs in order to create a formula for an alert for (Color Bar based on alert condition) for instance, i am struggling to find the exact name i need to put in my formula to extract information and put it in my study of another graph for instance, I want to put a alert message on my renko (graph20) and I want to extract my cumulative delta bar (ID2, close SG4) and compare it with my vwap grpah (ID4, sg1), and my volume profile levels (ID6 , vpoc (SG2), all of them are on the graph 22 =ID2.SG4(GRAPH22) (is that the right orthograph?) I just need the right way to put it on my formula, and I will be able to move forward. thank you for your time and answer |
[2025-03-13 20:25:36] |
John - SC Support - Posts: 39362 |
You cannot reference a different chart with Alerts. If there is information you need from another chart, then you need to overlay that information from that other chart to the chart where you are creating the alert condition. Refer to the following: Study/Price Overlay Study All of the information for how to setup alert conditions is at the following link: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
