Date/Time: Sat, 19 Apr 2025 15:23:44 +0000
Simulator hanging
View Count: 91
[2025-03-13 19:23:33] |
User190501 - Posts: 98 |
Hi Support, I am using simulator reply since a long time. This is the first time that I have noticed that the simulator has an odd behavior. Whenever you start it , it takes a pause and then close the entire application. I suspected it was due to my custom study but it is the same performance with other studies as well. I have installed another fresh installation and it has the same behavior. I am using the most current version as well. What could be the root cause of this issue ? |
[2025-03-13 20:15:37] |
Sierra_Chart Engineering - Posts: 19276 |
What is this you are referring to?: simulator reply
[2025-03-13 21:27:57] |
Typo -- Simulator Replay *
[2025-03-13 21:39:09] |
John - SC Support - Posts: 39362 |
The entire Sierra Chart application is shutting down when you run a replay? If not this, then what exactly is occurring? What are the parameters of the replay you are running (i.e. what charts, what type of replay, are you starting with a specific date and time)? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-13 21:52:13] |
If you have an abnormal shut down of Sierra Chart, refer to: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-13 21:52:21
