Date/Time: Sat, 19 Apr 2025 15:23:46 +0000
what orders work when PC is off?
View Count: 111
[2025-03-13 18:10:38]
User241663 - Posts: 4
Hello!
what kind of orders work when PC is off?
Stop orders and limit orders?
I had a move SL to breakeven which did not work, need to know what I can do in the future.
best regards,
Andi
[2025-03-13 19:56:22]
John - SC Support - Posts: 39362
It's going to depend on the trading service you are connected to. Refer to the following:
Attached Orders: Introduction
For services other than the "Teton Order Routing" a Move to Breakeven will only occur on the local system and is not something that the trading service deals with, so your Sierra Chart does need to be running to handle that move. With Teton, these orders are handled by our intermediary server, so you do not need your local Sierra Chart to be running.
[2025-03-13 20:16:18]
Sierra_Chart Engineering - Posts: 19276
Here is more information:
Order Types: Sierra Chart Management of Trailing Stop and Chase Orders
