Date/Time: Mon, 21 Apr 2025 04:41:26 +0000
[Programming Help] - Control Panel
View Count: 119
[2025-03-13 15:32:44] |
Tin43 - Posts: 141 |
Hi.. I got an indicator/strategy that i code in ACSIL, and i want to know if it is possible to "do/make" a Control Panel as the one on sierra chart but associated to an indicator/strategy I had coded with ACSIL? I mean, like this: https://imgur.com/a/sF3Bua4 (as the one in Sierra) but customized according the settings of the indicator. For example one button to BE, another to set the amount of TP, SL, amount of tick pullbacks, go long, go short, shut off trading.. etc etc. Some are common things, and some are very related to the indicator/strategy. Thanks in advance. |
