Date/Time: Mon, 15 Dec 2025 09:13:18 +0000
link my dorman account to Sierra
View Count: 257
| [2025-03-13 14:54:05] |
| KenjiVGH92 - Posts: 2 |
Hi Support Following my account opening with Dorman, I would like to know the process for connecting my account to my platform. I will use your own DENALI Eurex data feed. Thank you for your help. Kenji VONGSOUVANH |
| [2025-03-13 15:15:05] |
| John - SC Support - Posts: 43443 |
What order routing service are you using with Dorman? If you do not know, then you need to ask them this question. Once we know what service you are using, then we can point you to the proper instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
