Date/Time: Fri, 20 Sep 2024 05:35:12 +0000
2 Days left - but usage time has ended?
View Count: 988
[2014-09-24 13:00:04] |
User635132 - Posts: 2 |
Hi, every now and then there is something that is really annoying wth Sierra - apart from all the great features. Today it is the facht, that I'm not able to run Sierra because the usage time has ended - that says the message log. But the notification tells me that there are two days left. So I purchased more days. The root of all this seems to be that the computer clock is off - or it should be. But it is not. It's in synch. And also it seems that the other possibilities in the help topic can be excluded. This all costs a lot of time and I have to say that I think that this is not my part of the job. I know that this all is very complex because of the unlimited issues cmputers can cause, but... Please have a look...thanks ++++++++++++++++++ Sorry, even after synching the computer time several times it seems that there was a problem on my side. The date was ok, but the day was not... So sorry for this... Date Time Of Last Edit: 2014-09-24 15:43:05
[2014-09-24 16:02:43] |
Yes, the issue must have been with the computers date setting.
