Date/Time: Mon, 21 Apr 2025 04:47:15 +0000
Price settings Yen/Dollar
View Count: 546
[2025-03-13 09:49:16] |
User424153 - Posts: 1 |
Hi, The price on my chart is 0.000007 and I want it to be the same as the other picture (0.006790). I just can't figure out how.I looked everywhere Can someone point me in the right direction? |
[2025-03-13 14:46:23] |
John - SC Support - Posts: 39362 |
The tick size for 6J is 0.00005. So you should be seeing prices like 0.67595. Are you wanting to see the data with the additional decimal points for some reason? If you want the data showing like it is, then you need to adjust your "Chart >> Chart Settings >> Symbol >> Price Display Format" to show the additional fractional data, although there is a limit on how many are available. Refer to the following: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) If this is now what you want, and you are not sure why it is this way, then we recommend checking the "Real-Time Price Multiplier" and "Historical Price Multiplier" and adjusting these as appropriate to get the values to what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
