Date/Time: Mon, 21 Apr 2025 04:47:16 +0000
Data for Palm Oil Futures
View Count: 99
[2025-03-13 08:25:58]
User476186 - Posts: 5
I was wondering if Sierra Chart provide data for Palm Oil Futures from Bursa Malaysia Derivatives? I would really like to trade it using Sierra Chart. Any suggestions to how I can make this possible if Sierra Chart does not provide the data?
Thank you.
[2025-03-13 14:35:10]
John - SC Support - Posts: 39362
We do not have any data ourselves for Bursa Malaysia.
The first place to check is with your broker to see if they, or the order routing service you are using, has the data. In that case, you can use that data.
Otherwise, you can check with DTN IQ Feed to see if they have this data, which will allow you to chart, although you will not be able to trade directly from Sierra Chart in this case. Refer to the following:
DTN IQ Feed Data Service
[2025-03-13 14:55:33]
Hi John,
Assuming that my broker/ routing services has the data, how do I then proceed to connect it with Sierra so that it shows up on my chart?
Cheers.
[2025-03-13 15:17:29]
You would just need to enter the proper symbol for that service and data in the "Selected Symbol" field on the "File >> Find Symbol" window. Then open the type of chart you want from there.
