Date/Time: Sat, 19 Apr 2025 15:23:44 +0000
Two accounts on Sub Instance
View Count: 117
[2025-03-13 07:34:05]
StephenL - Posts: 120
Hi guys,
I have two separate trading accounts. I swapped from one account to the other on the Data log-in page, however in my sub-instance both accounts are now showing in the Trade Account Monitor.
How can I be sure I am executing through the correct account in the Sub Instance?
[2025-03-13 08:47:53]
Sierra_Chart Engineering - Posts: 19276
Do you see both accounts in the Trade >> Trade Account Monitor, in the main instance of Sierra Chart?
Date Time Of Last Edit: 2025-03-13 08:48:04
[2025-03-14 09:37:31]
Yea so turns out when I'd swap trading accounts, the Main Instance was always right and only shows the correct account in the Trade Account Monitor. But the Sub-Instances show up both accounts. Then if you Disconnect/Reconnect it'll revert to the proper trading. I should have checked that quickly before I posted.
While I'm here though, I also have two separate Front Ends for one account. Sierra will pick up the general account info (i.e. Positions, Open P&L etc). Do you know if there is a way to get trade fills executed from the other Front End onto the charts without manually importing?
[2025-03-14 13:43:23]
In the case of when using CQG this will happen automatically for the order fills for the same trading day as long as you are connecting to CQG before the end of the day. But not any prior fills .
We also see you are running an older version of Sierra Chart. You really should update to the current version. Instructions:
Date Time Of Last Edit: 2025-03-14 13:43:44
[2025-03-14 15:27:13]
Okay, thank you!
