Date/Time: Mon, 21 Apr 2025 04:44:12 +0000
trailing stop after tp 1 triggered
View Count: 66
[2025-03-12 18:24:14] |
User478874 - Posts: 7 |
Hello, I would like to know how to set a trailing stop after TP1 triggered
[2025-03-12 18:26:35] |
John - SC Support - Posts: 39362 |
Use a Stop order type of "Triggered Trailing Stop". Set the Trigger level to be the same as the TP1 you have and set the trailing as you want it. Refer to the following: Order Types: Triggered Trailing Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
