Date/Time: Tue, 04 Nov 2025 18:53:22 +0000
[User Discussion] - Colour Bar study
View Count: 1202
[2014-09-24 09:41:36]
User96105 - Posts: 113
I’d like to be able to colour the bars to show small orders, where the average trade size within that bar is, say, less than 5 contracts, and then a different colour to show large trades where the average trade size is, say, more than 50 contracts.
Is this possible using one of the standard colour bar studies?
[2014-09-24 09:44:31]
No. Quickly thinking about this, it seems rather involved to accomplish.
It would require custom programming and that is not within the scope of our support.
[2014-09-24 11:56:42]
Okay thanks ~ I'll have a go to see if I can do this with a spreadsheet study.
[2014-10-08 02:17:21]
Shane - Posts: 31
This is not that difficult to do. Average trade size is easy to calculate using a tick chart (SC calls it a "number of trades per bar" chart). Each bar is a fixed number of trades you define, say 1000 as an example.
Add a volume study. Your formula is then: volume / 1000. This is the average trade size.
If you want to display this value on some other kind of chart, you use study/price overlay to move it to the target chart and then a color bar by alert condition on the target chart that references the study/price overlay study.
I do this now and display average trade size above a certain threshold on range bar charts.
regards,
shane
