Date/Time: Mon, 21 Apr 2025 04:38:28 +0000
Bracket order Linked to account
View Count: 71
[2025-03-12 13:43:29] |
User318857 - Posts: 16 |
Hi there, Is there a way to link a bracket order with a specific account? and another to another account. So when I switch account the linked bracket order also switch Thk |
[2025-03-12 15:16:13] |
John - SC Support - Posts: 39362 |
There is not a way to have a specific order configuration associated by account using the built-in tools. Keep in mind you can change the Trade Configurations using keyboard shortcuts, so it can be done fairly quickly. You should be able to do what you want using a Custom Study. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.SelectedTradeAccount Automated Trading From an Advanced Custom Study: Programmatically Setting Trade Window Configuration https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
