Date/Time: Mon, 21 Apr 2025 04:47:15 +0000
Mots of VBP peaks not displaying
View Count: 97
[2025-03-12 01:39:11] |
User581066 - Posts: 31 |
Hi, I have a volume by Price study on my dom. The setting for peak and Valleys in set to show peaks only. But it only indicate and Draw a peak on the POC.Other levels that are very close to the POC are not marked. |
[2025-03-12 14:51:38] |
John - SC Support - Posts: 39362 |
Make sure your "Peaks and Valleys Sensitivity" is set to a value that will give you what you are wanting. It sounds like this may be set too high for what you want. Refer to the following: Volume By Price Study: Peaks and Valleys Sensitivity For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
