Date/Time: Fri, 20 Sep 2024 05:37:19 +0000
Measuring distance between levels
View Count: 1624
[2014-09-24 08:35:50] |
User27542 - Posts: 20 |
Hello, I wondered if there is a tool to measure distance automatically (eg. pips in forex) between two horizontal levels on a chart. I'm thinking of something similar to Metatrader, where you hold down left mouse button while dragging from one level to the other. With thanks for any help you can give. |
[2014-09-24 09:31:57] |
Yes. This is called the Chart Calculator: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-24 09:49:06] |
Many thanks for your help.
