Date/Time: Thu, 20 Mar 2025 02:11:45 +0000
Large Volume Trade Indicator
View Count: 126
[2025-03-11 19:03:35]
User796216 - Posts: 8
Large volume trade indicator draws very infrequently on very few days. Even when threshold set to as low as 10. It draws correctly but only once in awhile. This is on ES. There should be plenty of opportunity to draw. v. 2642. intraday data storage set to 1 tick. Thoughts?
[2025-03-11 20:16:59]
John - SC Support - Posts: 38812
A value of 10 should draw a fair number of markers. But what is your "Draw Mode" set to?
Also, we need to point out that you are getting your data from Rithmic. What you are seeing may be related to their data.
[2025-03-12 06:57:07]
Draw mode set to 'Based On Total Volume Above Threshold'. Altho, experimenting with different draw modes doesn't seem to help. What should I be looking for with Rithmic? Is there a work around? You guys are always great with your feedback! Thanks! - Joe.
[2025-03-12 15:04:57]
There is not an easy way to correlate what you see with the Large Volume Trade Indicator by looking at another study, since the Large Volume Trade Indicator is dealing with the individual trades.
You would need to either look at the "Time and Sales" for a particular time period over which a bar is formed and look for the individual trades, or use the "Edit >> Edit/Download Data - Intraday Chart" to look at the individual trades and make sure the numbers match up. But most likely this will all be consistent, otherwise our Large Volume Trade Indicator would not be working properly, which we do not think is the case (we have not had reports of issues with this study). Refer to the following:
Edit Menu: Edit >> Edit/Download Data - Intraday Chart
Attached is an image of the ES from our Denali Exchange Data Feed using a Threshold of 10. This should give you something to compare against. The time zone of the chart is Central US time.
Another thing you can try, is to install a second Sierra Chart and leave it connected to "SC Data" and you will get our Delayed Streaming Data. You can then compare our Denali data against Rithmic and see if what you are seeing is related to the data feeds. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Date Time Of Last Edit: 2025-03-12 15:06:25
imageSierra_Chart_MainWindow_2025-03-12 10_06_08.228.png / V - Attached On 2025-03-12 15:06:20 UTC - Size: 219.97 KB - 16 views
[2025-03-14 07:26:09]
Hi John - The Rithmic feed is the problem. I compared with SC Data which worked just fine. I'll figure it out from here. Thank you very much - Joe.
[2025-03-14 10:11:45]
Tr00pz - Posts: 20
Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
Enabling this will show more markers on your chart. If you set 'Draw Volume Text' in the Large Volume Trade Indicator study to show text, you'll also see that the values for some of the markers that were showing prior to enabling this setting will have increased slightly.
