Date/Time: Sat, 19 Apr 2025 15:23:47 +0000
customizin
View Count: 88
[2025-03-11 17:42:43] |
User282547 - Posts: 3 |
Hello, How can I change the color of the prices on the price scale of the chart? Also, how can I change the bottom horizontal line to white and the vertical line that separates the prices from the chart to green? Additionally, could you tell me how to make the TPOs of the first hour (9:30 AM - 10:30 AM, start of the US cash session) a different color? Please note that my TPO chart is always set to a 24-hour session. Thank you. |
[2025-03-11 17:51:17] |
John - SC Support - Posts: 39362 |
Refer to the following: Graphics Settings: Chart Values Scale Text Color Also, how can I change the bottom horizontal line to white and the vertical line that separates the prices from the chart to green?
Refer to the following: Graphics Settings: Chart Scale Border There are actually two lines drawn on the right side of the graphics area, so you may not see the color change unless you change the width of the item above. Additionally, could you tell me how to make the TPOs of the first hour (9:30 AM - 10:30 AM, start of the US cash session) a different color? Please note that my TPO chart is always set to a 24-hour session.
You would need to set your TPO Blocks/Letters to be colored based on the Letter/Block Color 1-18. Refer to the following: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
