Date/Time: Sat, 19 Apr 2025 15:21:50 +0000
'Location of Settings and to 'How to unload Global Graphics
View Count: 98
[2025-03-11 17:10:45] |
User838995 - Posts: 21 |
2] 2025-03-11 09:22:18 UTC | Username : kusumsharma | | Status : Open Subject updated from 'Location of Settings and how to.' to 'How to unload Global Graphic setting' -------------------------------------------------------------------------------- Hi, 1. I have unwittingly loaded a dotted line into my price action. I cannt even find it in Global settings now since dont remember what itis called and how to remove from the chart. It is right in between 19585 and 19580. Images dont have hyper links since I copied from your other location where Iposted first. I hope this is correct place to ask a question and help? https://www.sierrachart.com/image.php?Image=1741684918572.png Could you please point out as to where I can find the following two setting options to apply to a chart. 1. Centre line or half of chart line, drawn in yellow on price action. Also what does the constantly changing 50%, 60% and other small numbers beside ths line mean? 2. There is a price action showing on a horizontal line with dashed line. This line goes green and Red with the price. I am unable to find the settings and correct names for both of these as well. Image is attached. Thank you for your help. https://www.sierrachart.com/image.php?Image=1741680672401.png IP: 75.159.130.52 | Country: Canada | Region: Alberta |
[2025-03-11 19:54:44] |
John - SC Support - Posts: 39362 |
We responded to this in the Account Support Ticket you opened for this. Please respond in the Account Support Ticket.
