Date/Time: Sat, 19 Apr 2025 15:23:44 +0000
Data
View Count: 163
[2025-03-11 16:25:26] |
joew - Posts: 83 |
Frozen charts. Idk what the hell is going on.
[2025-03-11 16:34:06] |
John - SC Support - Posts: 39362 |
We responded to the other post where you stated this.
[2025-03-11 20:33:37] |
joew - Posts: 83 |
Nope. My footprint chart is just a blank chart. I need it fixed.
[2025-03-11 20:49:12] |
You are on Package 10 (Integrated Basic). This package does not support the use of the Numbers Bars study (along with a few others). You need to be on one of the "Advanced" packages to be able to use these studies. Refer to the following for the packages: Description of Service Packages and Pricing: Integrated Packages Refer to the following for how to change your package: Sierra Chart Purchase and License Information: Changing Package For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-11 21:12:21] |
joew - Posts: 83 |
For the love of god John, I've been specifically asking you since last week one question. "What do I need to get a footprint chart and a NQ bar chart?" That is all I wanted and I have repeatedly asked you to tell me exactly what I need and you absolutely refuse to give me a clear direct answer. Get your head out of your ass. You could have simply told me that last week and issue resolved. This was just a simple question that you made incredibly difficult.
Date Time Of Last Edit: 2025-03-11 21:12:41
[2025-03-11 21:19:20] |
joew - Posts: 83 |
You still didn't answer the question. Your answer, that I need to be on one of the more advanced packages, does not tell me what package I need to be on. Why can't you just tell me exactly what I need to do instead of referring me to a 600-page manual that I have no interest in reading. I know that you know what I want. I've asked you multiple times. Simple question. I need a NQ footprint chart and bar chart what is the cheapest package? Could you please just answer that question? The answer should sound something like, Joe you need package 17. This is the reason I stopped using Sierra. The support absolutely sucks.
