Date/Time: Sat, 19 Apr 2025 15:21:52 +0000
[User Discussion] - Low Bandwidth Mode for Teton Feed?
View Count: 112
[2025-03-11 14:27:47] |
esMike - Posts: 73 |
Is there any way to get a lower bandwidth mode? I get data delays upto 15-25 seconds in the /ES futures during heavy volume times when my DSL connection cannot keep up. |
[2025-03-11 15:54:13] |
John - SC Support - Posts: 39362 |
Refer to the following for what can be done: Prices / Data Falling Behind: 4.9 - Reducing Network Bandwidth Requirements for Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-11 18:38:27] |
Oh, remote data buffer and higher compression helps a lot. No more data delay buildups. Thanks!
