Date/Time: Wed, 19 Mar 2025 03:24:39 +0000
ES H contract mkt data slow and lagging - BIG PROBLEM
View Count: 184
[2025-03-11 13:55:02] |
User114488 - Posts: 9 |
URGENT PLEASE CORRECT
[2025-03-11 15:50:07] |
John - SC Support - Posts: 38782 |
We need more information on what exactly is occurring. There is nothing happening on our end, everything is moving fine for the data.
[2025-03-11 16:01:06] |
My sierra dom and chart are lagging behind my interactive brokers quotes, sometimes off by 8 or 10 ticks. You tell me wht else specifically I can do to help trouble shoot this
[2025-03-11 16:10:29] |
If you are still having an issue, then we would like to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-11 16:26:01] |
2025-03-11 08:51:44.294 | Trade activity files set size: 1238 2025-03-11 08:51:44.340 | Reading Internal Order ID file. 2025-03-11 08:51:44.370 | Reading Trade Orders file. 2025-03-11 08:51:44.370 | Reading Trade Positions file. 2025-03-11 08:51:44.370 | Reading Trade Account Data files. 2025-03-11 08:51:44.373 | UDPListener (1660). Port 22904 | Listening on UDP port 22904. 2025-03-11 08:51:44.373 | Software version: 2744 64-bit 2025-03-11 08:51:44.373 | Primary Thread ID: 30848 2025-03-11 08:51:44.373 | Usage end date: 2025-06-05 2025-03-11 08:51:44.373 | Enabled for: Sierra Chart Historical Data Service. 2025-03-11 08:51:44.373 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-03-11 08:51:44.373 | Enabled for: Delayed Denali Exchange Data Feed. 2025-03-11 08:51:44.373 | Enabled for exchange2: CME (Trading Account Required) 2025-03-11 08:51:44.373 | Enabled for exchange2: CBOT (Trading Account Required) 2025-03-11 08:51:44.373 | Enabled for exchange2: COMEX (Trading Account Required) 2025-03-11 08:51:44.373 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-03-11 08:51:44.373 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-03-11 08:51:44.373 | Current selected Data/Trading service: Teton CME Routing 2025-03-11 08:51:44.373 | Custom symbol settings values: disabled 2025-03-11 08:51:44.373 | Chart Update Interval: 500 2025-03-11 08:51:44.373 | Intraday Data Storage Time Unit: 0 2025-03-11 08:51:44.373 | Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-03-11 08:51:44.373 | 2025-03-11 13:51:44 Local computer time in UTC 2025-03-11 08:51:44.373 | 2025-03-11 08:51:44 Local computer time in SC Time Zone 2025-03-11 08:51:44.373 | 2025-03-11 13:51:44 Server time in UTC 2025-03-11 08:51:44.373 | Local computer UTC time and Server UTC time difference: 0 seconds. 2025-03-11 08:51:44.373 | Program path: C:\SierraChart\ 2025-03-11 08:51:44.373 | Data Files path: C:\SierraChart\Data\ 2025-03-11 08:51:44.373 | OS Version Number: 10.0 2025-03-11 08:51:44.373 | Locale Setting: C 2025-03-11 08:51:44.373 | DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll 2025-03-11 08:51:44.373 | Allowed protected custom studies: 2025-03-11 08:51:44.373 | Crash reporter started: true 2025-03-11 08:51:44.373 | 2025-03-11 08:51:44.373 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2025-03-11 08:51:44.400 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-03-11 08:51:44.425 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-03-11 08:51:44.425 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-03-11 08:51:44.473 | Received 5 login tokens. 2025-03-11 08:51:44.858 | Symbol settings MD5 received. Request ID: 1. 2025-03-11 08:51:44.858 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2025-03-11 08:51:46.872 | Requested user files to download. 2025-03-11 08:51:48.878 | 2025-03-11 08:51:48.878 | Teton CME Routing | Firm: AMP 2025-03-11 08:51:48.879 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-03-11 08:51:48.942 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-03-11 08:51:48.943 | DTC Client socket (1) | New receive buffer size: 0 2025-03-11 08:51:48.943 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-03-11 08:51:48.955 | Teton CME Routing | Network connection to server complete. 2025-03-11 08:51:48.955 | Teton CME Routing | Starting socket receive thread. 2025-03-11 08:51:48.955 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-03-11 08:51:49.022 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-03-11 08:51:49.022 | Teton CME Routing | Sending logon request message. 2025-03-11 08:51:49.100 | Teton CME Routing | Received logon response. 2025-03-11 08:51:49.100 | Teton CME Routing | Server Name: SC DTC Server. Build=52282. 2025-03-11 08:51:49.100 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-03-11 08:51:49.100 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-03-11 08:51:49.100 | Teton CME Routing | Trading is supported. 2025-03-11 08:51:49.100 | Teton CME Routing | Order cancel and replace is supported. 2025-03-11 08:51:49.100 | Teton CME Routing | OCO Orders supported. 2025-03-11 08:51:49.100 | Teton CME Routing | Bracket Orders supported. 2025-03-11 08:51:49.100 | Teton CME Routing | MarketDepthIsSupported: 1 2025-03-11 08:51:49.100 | Teton CME Routing | Connected to server complete. 2025-03-11 08:51:49.100 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-03-11 08:51:49.100 | Mapping ESU20_FUT_CME to ESU20. Service code: cme 2025-03-11 08:51:49.100 | Using symbol data fast lookup vector 2025-03-11 08:51:49.100 | Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 1 Service code: cme 2025-03-11 08:51:49.102 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2025-03-11 08:51:49.102 | Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 1 2025-03-11 08:51:49.102 | Starting DelayedDownloadMonitoringTimer 2025-03-11 08:51:49.102 | Starting HDTimeoutTimer 2025-03-11 08:51:49.102 | Added historical Intraday data request for ESU20_FUT_CME to the queue. 2025-03-11 08:51:49.102 | Intraday data recording state for symbol ESU20_FUT_CME is set to download 'Pending'. 2025-03-11 08:51:49.102 | DTC Client socket (2) | Creating socket. 2025-03-11 08:51:49.102 | DTC Client socket (2) | New receive buffer size: 0 2025-03-11 08:51:49.102 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2025-03-11 08:51:49.103 | Triggering next historical data download in queue. 2025-03-11 08:51:49.103 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-03-11 08:51:49.103 | Delaying start of download for ESU20_FUT_CME. 2025-03-11 08:51:49.110 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-03-11 13:44:38.543982 2025-03-11 08:51:49.120 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME 2025-03-11 08:51:49.120 | Teton CME Routing | Setting external service identifier for symbol ESU20_FUT_CME to 193 2025-03-11 08:51:49.120 | Teton CME Routing | Received security definition for symbol ESU20_FUT_CME 2025-03-11 08:51:49.123 | Updated verified funded futures trading account ending date to: 2025-04-10 13:51:49 2025-03-11 08:51:49.123 | Denali Data Feed | Network connection to server complete. 2025-03-11 08:51:49.123 | Denali Data Feed | Starting socket receive thread. 2025-03-11 08:51:49.123 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-03-11 08:51:49.176 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-03-11 08:51:49.176 | Denali Data Feed | Sending logon request message. 2025-03-11 08:51:49.198 | Teton CME Routing | Received final trade activity snapshot. Count=2. TradeAccount=116842 2025-03-11 08:51:49.643 | Denali Data Feed | Received logon response. 2025-03-11 08:51:49.643 | Denali Data Feed | Server Name: SC Realtime Server. 2025-03-11 08:51:49.643 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-03-11 08:51:49.643 | Denali Data Feed | Successfully connected. 2025-03-11 08:51:49.643 | Denali Data Feed | Trading is not supported. 2025-03-11 08:51:49.643 | Denali Data Feed | MarketDepthIsSupported: 1 2025-03-11 08:51:49.643 | Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 2025-03-11 08:51:49.768 | Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. 2025-03-11 08:51:49.768 | Denali Data Feed | Received security definition for symbol ESU20_FUT_CME 2025-03-11 08:51:52.675 | esH25_FUT_CME 5 Min #1 | Reloading chart. 2025-03-11 08:51:53.185 | Mapping esH25_FUT_CME to ESH25. Service code: cme 2025-03-11 08:51:53.185 | Denali Data Feed | Starting real-time market data updates for: esH25_FUT_CME (ESH25). ID: 2 Service code: cme 2025-03-11 08:51:53.185 | Denali Data Feed | Requesting security definition data for: esH25_FUT_CME (ESH25). ID: 2 2025-03-11 08:51:53.186 | Added historical Intraday data request for esH25_FUT_CME to the queue. 2025-03-11 08:51:53.186 | Intraday data recording state for symbol esH25_FUT_CME is set to download 'Pending'. 2025-03-11 08:51:53.186 | Triggering next historical data download in queue. 2025-03-11 08:51:53.208 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: esH25_FUT_CME 2025-03-11 08:51:53.208 | Teton CME Routing | Setting external service identifier for symbol esH25_FUT_CME to 5002 2025-03-11 08:51:53.208 | Teton CME Routing | Received security definition for symbol esH25_FUT_CME 2025-03-11 08:51:53.270 | esH25_FUT_CME[M] 5 Min #1 | Chart data loading complete. 2025-03-11 08:51:53.304 | Denali Data Feed | Setting external service identifier for symbol esH25_FUT_CME to 5002 2025-03-11 08:51:53.304 | Denali Data Feed | Received security definition for symbol esH25_FUT_CME 2025-03-11 08:51:54.104 | HD Request # 1 | Downloading Intraday chart data for ESU20_FUT_CME to the file ESU20_FUT_CME.scid. Service: cme 2025-03-11 08:51:54.104 | HD Request # 1 | Download start date-time: 2020-09-18 08:29:59.000000. File last date-time: 2020-09-18 08:29:59.270000 2025-03-11 08:51:54.104 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149 2025-03-11 08:51:54.104 | Socket (3) | Creating socket. 2025-03-11 08:51:54.104 | Socket (3) | New receive buffer size: 0 2025-03-11 08:51:54.104 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-03-11 08:51:54.154 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-03-11 08:51:54.154 | HD Request # 1 | Sending historical data logon request message. 2025-03-11 08:51:54.223 | HD Request # 1 | Requesting Intraday data. Start date-time: 2020-09-18 08:29:59. Record interval: 0. Symbol: ESU20 2025-03-11 08:51:54.251 | HD Request # 1 | Decompressing data. 2025-03-11 08:51:54.277 | HD Request # 1 | Receiving Intraday data for ESU20_FUT_CME starting at 2020-09-18 08:29:59.270000 2025-03-11 08:51:54.277 | Socket (3) | CloseSocket call. 2025-03-11 08:51:54.277 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-03-11 08:51:54.278 | Historical data download thread signaled to stop. 2025-03-11 08:51:54.278 | HD Request # 1 | Received 1 Intraday data record from 2020-09-18 08:29:59.270000 to 2020-09-18 08:29:59.270000 (0.0 seconds. Delay: 4.5 years) and wrote 0 records for ESU20_FUT_CME 2025-03-11 08:51:54.278 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2020-09-18 13:29:59.270000 2025-03-11 08:51:54.278 | HD Request # 1 | Completion time: 0s. 2025-03-11 08:51:54.278 | HD Request # 1 | Intraday data download complete for ESU20_FUT_CME. Unique request ID: 1 2025-03-11 08:51:54.278 | Removing historical data download ID 1. 2025-03-11 08:51:54.278 | Real-time Intraday chart data file updates started for ESU20_FUT_CME 2025-03-11 08:51:54.278 | Intraday chart data file opened for ESU20_FUT_CME 2025-03-11 08:51:54.278 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2025-03-11 08:51:54.278 | 2025-03-11 08:51:54.278 | Triggering next historical data download in queue. 2025-03-11 08:51:54.278 | Delaying start of download for esH25_FUT_CME. 2025-03-11 08:51:54.298 | Socket (3) | Socket gracefully closed by remote side. 2025-03-11 08:51:54.298 | Socket (3) | Closed. 2025-03-11 08:51:58.107 | HD Request # 2 | Downloading Intraday chart data for esH25_FUT_CME to the file esH25_FUT_CME.scid. Service: cme 2025-03-11 08:51:58.107 | HD Request # 2 | Download start date-time: 2025-03-11 08:51:30.000000. File last date-time: 2025-03-11 08:51:30.005000 2025-03-11 08:51:58.107 | HD Request # 2 | Using server: ds32.sierracharts.com port 10150 2025-03-11 08:51:58.108 | Socket (3) | Creating socket. 2025-03-11 08:51:58.108 | Socket (3) | New receive buffer size: 0 2025-03-11 08:51:58.108 | Socket (3) | Connecting to IP: 67.214.125.3. 2025-03-11 08:51:58.161 | HD Request # 2 | Setting DTC encoding to Binary VLS 2025-03-11 08:51:58.161 | HD Request # 2 | Sending historical data logon request message. 2025-03-11 08:51:58.228 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-03-11 08:51:30. Record interval: 0. Symbol: ESH25 2025-03-11 08:51:58.249 | ESH25_FUT_CME 1 Min #2 | Reloading chart. 2025-03-11 08:51:58.253 | HD Request # 2 | Decompressing data. 2025-03-11 08:51:58.282 | HD Request # 2 | Receiving Intraday data for esH25_FUT_CME starting at 2025-03-11 08:51:30.002000 2025-03-11 08:51:58.284 | Socket (3) | CloseSocket call. 2025-03-11 08:51:58.284 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-03-11 08:51:58.308 | Socket (3) | Socket gracefully closed by remote side. 2025-03-11 08:51:58.308 | Socket (3) | Closed. 2025-03-11 08:51:58.400 | ESH25_FUT_CME #3 | Reloading chart. 2025-03-11 08:51:58.401 | ESH25_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2025-03-11 08:51:58.409 | ESH25_FUT_CME #3 | Chart data loading complete. 2025-03-11 08:51:58.413 | Historical data download thread signaled to stop. 2025-03-11 08:51:58.413 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-03-11 08:51:30.034000. 2025-03-11 08:51:58.413 | HD Request # 2 | Received 2688 Intraday data records from 2025-03-11 08:51:30.002000 to 2025-03-11 08:51:54.688000 (24.7 seconds. Delay: 3.7 seconds) and wrote 2685 records for esH25_FUT_CME 2025-03-11 08:51:58.419 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-03-11 13:51:54.688000 2025-03-11 08:51:58.419 | Added 364 Time and Sales records to Intraday data file for esH25_FUT_CME after download. 2025-03-11 08:51:58.419 | HD Request # 2 | Completion time: 0s. 2025-03-11 08:51:58.419 | HD Request # 2 | Intraday data download complete for esH25_FUT_CME. Unique request ID: 2 2025-03-11 08:51:58.419 | Removing historical data download ID 2. 2025-03-11 08:51:58.419 | Real-time Intraday chart data file updates started for esH25_FUT_CME 2025-03-11 08:51:58.419 | Intraday chart data file opened for esH25_FUT_CME 2025-03-11 08:51:58.419 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2025-03-11 08:51:58.419 | 2025-03-11 08:51:58.419 | No download requests in the queue to start downloads for. 2025-03-11 08:51:58.850 | ESH25_FUT_CME[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2025-03-11 08:51:58.857 | ESH25_FUT_CME[M] 1 Min #2 | Chart data loading complete. 2025-03-11 08:51:59.107 | Requesting market depth updates for: esH25_FUT_CME if supported. NumLevels=100 2025-03-11 08:51:59.223 | Denali Data Feed | Clearing market depth for esH25_FUT_CME 2025-03-11 08:51:59.399 | Opened cached Intraday file: C:\SierraChart\Data\esH25_FUT_CME.scid. Thread ID: 25432 2025-03-11 08:52:09.125 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2025-03-11 08:52:09.321 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-04-09"}. Success=true 2025-03-11 08:52:42.238 | File >> Disconnect selected. 2025-03-11 08:52:42.239 | Teton CME Routing | Waiting for socket receive thread to end 2025-03-11 08:52:42.239 | DTC Client socket (1) | CloseSocket call. 2025-03-11 08:52:42.239 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-03-11 08:52:42.239 | DTC Client socket (1) | Max send buffer size during socket life: 236 2025-03-11 08:52:42.239 | Denali Data Feed | Waiting for socket receive thread to end 2025-03-11 08:52:42.239 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-03-11 08:52:42.239 | DTC Client socket (2) | CloseSocket call. 2025-03-11 08:52:42.240 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-03-11 08:52:42.240 | Denali Data Feed | Disconnected from the server. 2025-03-11 08:52:42.240 | Teton CME Routing | Disconnected. 2025-03-11 08:52:42.254 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-03-11 08:52:42.255 | DTC Client socket (1) | Closed. 2025-03-11 08:52:42.327 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-03-11 08:52:42.327 | DTC Client socket (2) | Closed. 2025-03-11 08:52:47.820 | 2025-03-11 08:52:47.820 | Teton CME Routing | Firm: AMP 2025-03-11 08:52:47.820 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-03-11 08:52:47.820 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-03-11 08:52:47.820 | DTC Client socket (1) | New receive buffer size: 0 2025-03-11 08:52:47.820 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-03-11 08:52:47.834 | Teton CME Routing | Network connection to server complete. 2025-03-11 08:52:47.834 | Teton CME Routing | Starting socket receive thread. 2025-03-11 08:52:47.834 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-03-11 08:52:47.894 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-03-11 08:52:47.894 | Teton CME Routing | Sending logon request message. 2025-03-11 08:52:47.911 | Teton CME Routing | Received logon response. 2025-03-11 08:52:47.911 | Teton CME Routing | Server Name: SC DTC Server. Build=52282. 2025-03-11 08:52:47.911 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-03-11 08:52:47.911 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-03-11 08:52:47.911 | Teton CME Routing | Trading is supported. 2025-03-11 08:52:47.911 | Teton CME Routing | Order cancel and replace is supported. 2025-03-11 08:52:47.911 | Teton CME Routing | OCO Orders supported. 2025-03-11 08:52:47.911 | Teton CME Routing | Bracket Orders supported. 2025-03-11 08:52:47.911 | Teton CME Routing | MarketDepthIsSupported: 1 2025-03-11 08:52:47.911 | Teton CME Routing | Connected to server complete. 2025-03-11 08:52:47.911 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-03-11 08:52:47.911 | Mapping ESU20_FUT_CME to ESU20. Service code: cme 2025-03-11 08:52:47.911 | Using symbol data fast lookup vector 2025-03-11 08:52:47.911 | Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 1 Service code: cme 2025-03-11 08:52:47.911 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443 2025-03-11 08:52:47.912 | Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 1 2025-03-11 08:52:47.912 | Added historical Intraday data request for ESU20_FUT_CME to the queue. 2025-03-11 08:52:47.912 | Intraday data recording state for symbol ESU20_FUT_CME is set to download 'Pending'. 2025-03-11 08:52:47.912 | Triggering next historical data download in queue. 2025-03-11 08:52:47.912 | Updated verified funded futures trading account ending date to: 2025-04-10 13:52:47 2025-03-11 08:52:47.913 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-03-11 08:52:47.913 | Delaying start of download for ESU20_FUT_CME. 2025-03-11 08:52:47.924 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-03-11 13:44:38.864645 2025-03-11 08:52:47.928 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME 2025-03-11 08:52:47.928 | Teton CME Routing | Setting external service identifier for symbol ESU20_FUT_CME to 193 2025-03-11 08:52:47.928 | Teton CME Routing | Received security definition for symbol ESU20_FUT_CME 2025-03-11 08:52:47.933 | Updated verified funded futures trading account ending date to: 2025-04-10 13:52:47 2025-03-11 08:52:47.971 | DTC Client socket (2) | Creating socket. 2025-03-11 08:52:47.971 | DTC Client socket (2) | New receive buffer size: 0 2025-03-11 08:52:47.971 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2025-03-11 08:52:47.995 | Denali Data Feed | Network connection to server complete. 2025-03-11 08:52:47.995 | Denali Data Feed | Starting socket receive thread. 2025-03-11 08:52:47.995 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-03-11 08:52:48.020 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=116842 2025-03-11 08:52:48.035 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-03-11 08:52:48.035 | Denali Data Feed | Sending logon request message. 2025-03-11 08:52:48.062 | Mapping ESH25_FUT_CME to ESH25. Service code: cme 2025-03-11 08:52:48.062 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 2 Service code: cme 2025-03-11 08:52:48.062 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 2 2025-03-11 08:52:48.062 | Added historical Intraday data request for ESH25_FUT_CME to the queue. 2025-03-11 08:52:48.062 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'. 2025-03-11 08:52:48.062 | Triggering next historical data download in queue. 2025-03-11 08:52:48.083 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME 2025-03-11 08:52:48.083 | Teton CME Routing | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-03-11 08:52:48.083 | Teton CME Routing | Received security definition for symbol ESH25_FUT_CME 2025-03-11 08:52:48.506 | Denali Data Feed | Received logon response. 2025-03-11 08:52:48.506 | Denali Data Feed | Server Name: SC Realtime Server. 2025-03-11 08:52:48.506 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-03-11 08:52:48.506 | Denali Data Feed | Successfully connected. 2025-03-11 08:52:48.506 | Denali Data Feed | Trading is not supported. 2025-03-11 08:52:48.506 | Denali Data Feed | MarketDepthIsSupported: 1 2025-03-11 08:52:48.506 | Denali Data Feed | Restarting real-time data updates for symbol: ESH25_FUT_CME -> ESH25 2025-03-11 08:52:48.506 | Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 2025-03-11 08:52:48.631 | Denali Data Feed | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-03-11 08:52:48.631 | Denali Data Feed | Received security definition for symbol ESH25_FUT_CME 2025-03-11 08:52:48.631 | Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. 2025-03-11 08:52:48.631 | Denali Data Feed | Received security definition for symbol ESU20_FUT_CME 2025-03-11 08:52:52.910 | Requesting market depth updates for: ESH25_FUT_CME if supported. NumLevels=100 2025-03-11 08:52:53.015 | Denali Data Feed | Clearing market depth for ESH25_FUT_CME 2025-03-11 08:52:53.127 | HD Request # 3 | Downloading Intraday chart data for ESU20_FUT_CME to the file ESU20_FUT_CME.scid. Service: cme 2025-03-11 08:52:53.127 | HD Request # 3 | Download start date-time: 2020-09-18 08:29:59.000000. File last date-time: 2020-09-18 08:29:59.270000 2025-03-11 08:52:53.127 | HD Request # 3 | Using server: ds26.sierracharts.com port 10149 2025-03-11 08:52:53.128 | Socket (3) | Creating socket. 2025-03-11 08:52:53.128 | Socket (3) | New receive buffer size: 0 2025-03-11 08:52:53.128 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-03-11 08:52:53.175 | HD Request # 3 | Setting DTC encoding to Binary VLS 2025-03-11 08:52:53.175 | HD Request # 3 | Sending historical data logon request message. 2025-03-11 08:52:53.238 | HD Request # 3 | Requesting Intraday data. Start date-time: 2020-09-18 08:29:59. Record interval: 0. Symbol: ESU20 2025-03-11 08:52:53.261 | HD Request # 3 | Decompressing data. 2025-03-11 08:52:53.285 | HD Request # 3 | Receiving Intraday data for ESU20_FUT_CME starting at 2020-09-18 08:29:59.270000 2025-03-11 08:52:53.285 | Socket (3) | CloseSocket call. 2025-03-11 08:52:53.285 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-03-11 08:52:53.286 | Historical data download thread signaled to stop. 2025-03-11 08:52:53.286 | HD Request # 3 | Received 1 Intraday data record from 2020-09-18 08:29:59.270000 to 2020-09-18 08:29:59.270000 (0.0 seconds. Delay: 4.5 years) and wrote 0 records for ESU20_FUT_CME 2025-03-11 08:52:53.287 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2020-09-18 13:29:59.270000 2025-03-11 08:52:53.287 | HD Request # 3 | Completion time: 0s. 2025-03-11 08:52:53.287 | HD Request # 3 | Intraday data download complete for ESU20_FUT_CME. Unique request ID: 3 2025-03-11 08:52:53.287 | Removing historical data download ID 3. 2025-03-11 08:52:53.287 | Real-time Intraday chart data file updates started for ESU20_FUT_CME 2025-03-11 08:52:53.287 | Intraday chart data file opened for ESU20_FUT_CME 2025-03-11 08:52:53.287 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2025-03-11 08:52:53.287 | 2025-03-11 08:52:53.287 | Triggering next historical data download in queue. 2025-03-11 08:52:53.287 | HD Request # 4 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme 2025-03-11 08:52:53.287 | HD Request # 4 | Download start date-time: 2025-03-11 08:52:42.000000. File last date-time: 2025-03-11 08:52:42.382004 2025-03-11 08:52:53.287 | HD Request # 4 | Using server: ds28.sierracharts.com port 10150 2025-03-11 08:52:53.287 | Socket (4) | Creating socket. 2025-03-11 08:52:53.287 | Socket (4) | New receive buffer size: 0 2025-03-11 08:52:53.287 | Socket (4) | Connecting to IP: 67.214.125.5. 2025-03-11 08:52:53.307 | Socket (3) | Socket gracefully closed by remote side. 2025-03-11 08:52:53.307 | Socket (3) | Closed. 2025-03-11 08:52:53.333 | HD Request # 4 | Setting DTC encoding to Binary VLS 2025-03-11 08:52:53.333 | HD Request # 4 | Sending historical data logon request message. 2025-03-11 08:52:53.402 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-03-11 08:52:42. Record interval: 0. Symbol: ESH25 2025-03-11 08:52:53.429 | HD Request # 4 | Decompressing data. 2025-03-11 08:52:53.451 | HD Request # 4 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-03-11 08:52:42.009000 2025-03-11 08:52:53.451 | Socket (4) | CloseSocket call. 2025-03-11 08:52:53.451 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-03-11 08:52:53.452 | Historical data download thread signaled to stop. 2025-03-11 08:52:53.452 | HD Request # 4 | Timestamp of first Intraday data file record written: 2025-03-11 08:52:42.567000. 2025-03-11 08:52:53.452 | HD Request # 4 | Received 655 Intraday data records from 2025-03-11 08:52:42.009000 to 2025-03-11 08:52:50.849002 (8.8 seconds. Delay: 2.6 seconds) and wrote 619 records for ESH25_FUT_CME 2025-03-11 08:52:53.460 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-03-11 13:52:50.849002 2025-03-11 08:52:53.460 | Added 150 Time and Sales records to Intraday data file for ESH25_FUT_CME after download. 2025-03-11 08:52:53.460 | HD Request # 4 | Completion time: 0s. 2025-03-11 08:52:53.460 | HD Request # 4 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 4 2025-03-11 08:52:53.460 | Removing historical data download ID 4. 2025-03-11 08:52:53.460 | Real-time Intraday chart data file updates started for ESH25_FUT_CME 2025-03-11 08:52:53.460 | Intraday chart data file opened for ESH25_FUT_CME 2025-03-11 08:52:53.460 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2025-03-11 08:52:53.460 | 2025-03-11 08:52:53.460 | No download requests in the queue to start downloads for. 2025-03-11 08:52:53.477 | Socket (4) | Socket gracefully closed by remote side. 2025-03-11 08:52:53.477 | Socket (4) | Closed. 2025-03-11 08:52:54.495 | Opened cached Intraday file: C:\SierraChart\Data\ESH25_FUT_CME.scid. Thread ID: 25432 2025-03-11 09:34:16.920 | ESH25_FUT_CME[M] 5 Sec #2 | Reloading chart. 2025-03-11 09:34:17.581 | ESH25_FUT_CME[M] 5 Sec #2 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2025-03-11 09:34:17.587 | ESH25_FUT_CME[M] 5 Sec #2 | Chart data loading complete. 2025-03-11 11:22:42.762 | Saved Chartbook: EdgeZones Trading Room.Cht. Time: 0.0006 seconds. 2025-03-11 11:22:42.763 | Saved Chartbook: Chartbook3.Cht. Time: 0.0005 seconds. 2025-03-11 11:22:43.029 | Unsubscribed from market depth data for ESH25_FUT_CME 2025-03-11 11:23:11.991 | ESH25_FUT_CME 1 Min #1 | Reloading chart. 2025-03-11 11:23:12.688 | ESH25_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2025-03-11 11:23:24.071 | File >> Disconnect selected. 2025-03-11 11:23:24.071 | Teton CME Routing | Waiting for socket receive thread to end 2025-03-11 11:23:24.071 | DTC Client socket (1) | CloseSocket call. 2025-03-11 11:23:24.071 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-03-11 11:23:24.071 | DTC Client socket (1) | Max send buffer size during socket life: 329 2025-03-11 11:23:24.071 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-03-11 11:23:24.072 | Denali Data Feed | Waiting for socket receive thread to end 2025-03-11 11:23:24.072 | DTC Client socket (2) | CloseSocket call. 2025-03-11 11:23:24.072 | Denali Data Feed | Disconnected from the server. 2025-03-11 11:23:24.072 | Teton CME Routing | Disconnected. 2025-03-11 11:23:24.072 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-03-11 11:23:24.089 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-03-11 11:23:24.089 | DTC Client socket (1) | Closed. 2025-03-11 11:23:24.166 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-03-11 11:23:24.166 | DTC Client socket (2) | Closed. 2025-03-11 11:23:33.829 | 2025-03-11 11:23:33.829 | Teton CME Routing | Firm: AMP 2025-03-11 11:23:33.829 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-03-11 11:23:33.882 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-03-11 11:23:33.882 | DTC Client socket (1) | New receive buffer size: 0 2025-03-11 11:23:33.883 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-03-11 11:23:33.899 | Teton CME Routing | Network connection to server complete. 2025-03-11 11:23:33.899 | Teton CME Routing | Starting socket receive thread. 2025-03-11 11:23:33.899 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-03-11 11:23:33.956 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-03-11 11:23:33.956 | Teton CME Routing | Sending logon request message. 2025-03-11 11:23:34.041 | Teton CME Routing | Received logon response. 2025-03-11 11:23:34.041 | Teton CME Routing | Server Name: SC DTC Server. Build=52282. 2025-03-11 11:23:34.041 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-03-11 11:23:34.041 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-03-11 11:23:34.041 | Teton CME Routing | Trading is supported. 2025-03-11 11:23:34.041 | Teton CME Routing | Order cancel and replace is supported. 2025-03-11 11:23:34.041 | Teton CME Routing | OCO Orders supported. 2025-03-11 11:23:34.041 | Teton CME Routing | Bracket Orders supported. 2025-03-11 11:23:34.041 | Teton CME Routing | MarketDepthIsSupported: 1 2025-03-11 11:23:34.041 | Teton CME Routing | Connected to server complete. 2025-03-11 11:23:34.042 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-03-11 11:23:34.042 | Mapping ESU20_FUT_CME to ESU20. Service code: cme 2025-03-11 11:23:34.042 | Using symbol data fast lookup vector 2025-03-11 11:23:34.042 | Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 1 Service code: cme 2025-03-11 11:23:34.042 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048 2025-03-11 11:23:34.042 | Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 1 2025-03-11 11:23:34.042 | Added historical Intraday data request for ESU20_FUT_CME to the queue. 2025-03-11 11:23:34.042 | Intraday data recording state for symbol ESU20_FUT_CME is set to download 'Pending'. 2025-03-11 11:23:34.042 | Triggering next historical data download in queue. 2025-03-11 11:23:34.042 | Updated verified funded futures trading account ending date to: 2025-04-10 16:23:34 2025-03-11 11:23:34.042 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-03-11 11:23:34.042 | Delaying start of download for ESU20_FUT_CME. 2025-03-11 11:23:34.051 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-03-11 16:21:05.153160 2025-03-11 11:23:34.058 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME 2025-03-11 11:23:34.058 | Teton CME Routing | Setting external service identifier for symbol ESU20_FUT_CME to 193 2025-03-11 11:23:34.058 | Teton CME Routing | Received security definition for symbol ESU20_FUT_CME 2025-03-11 11:23:34.065 | Updated verified funded futures trading account ending date to: 2025-04-10 16:23:34 2025-03-11 11:23:34.082 | DTC Client socket (2) | Creating socket. 2025-03-11 11:23:34.082 | DTC Client socket (2) | New receive buffer size: 0 2025-03-11 11:23:34.082 | DTC Client socket (2) | Connecting to IP: 67.214.125.4. 2025-03-11 11:23:34.108 | Denali Data Feed | Network connection to server complete. 2025-03-11 11:23:34.108 | Denali Data Feed | Starting socket receive thread. 2025-03-11 11:23:34.108 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-03-11 11:23:34.158 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-03-11 11:23:34.158 | Denali Data Feed | Sending logon request message. 2025-03-11 11:23:34.282 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=116842 2025-03-11 11:23:34.386 | Mapping ESH25_FUT_CME to ESH25. Service code: cme 2025-03-11 11:23:34.386 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 2 Service code: cme 2025-03-11 11:23:34.386 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 2 2025-03-11 11:23:34.386 | Added historical Intraday data request for ESH25_FUT_CME to the queue. 2025-03-11 11:23:34.386 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'. 2025-03-11 11:23:34.386 | Triggering next historical data download in queue. 2025-03-11 11:23:34.403 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME 2025-03-11 11:23:34.403 | Teton CME Routing | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-03-11 11:23:34.403 | Teton CME Routing | Received security definition for symbol ESH25_FUT_CME 2025-03-11 11:23:34.661 | Denali Data Feed | Received logon response. 2025-03-11 11:23:34.661 | Denali Data Feed | Server Name: SC Realtime Server. 2025-03-11 11:23:34.661 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-03-11 11:23:34.661 | Denali Data Feed | Successfully connected. 2025-03-11 11:23:34.661 | Denali Data Feed | Trading is not supported. 2025-03-11 11:23:34.661 | Denali Data Feed | MarketDepthIsSupported: 1 2025-03-11 11:23:34.661 | Denali Data Feed | Restarting real-time data updates for symbol: ESH25_FUT_CME -> ESH25 2025-03-11 11:23:34.661 | Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 2025-03-11 11:23:34.784 | Denali Data Feed | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-03-11 11:23:34.784 | Denali Data Feed | Received security definition for symbol ESH25_FUT_CME 2025-03-11 11:23:34.784 | Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. 2025-03-11 11:23:34.784 | Denali Data Feed | Received security definition for symbol ESU20_FUT_CME 2025-03-11 11:23:39.037 | HD Request # 5 | Downloading Intraday chart data for ESU20_FUT_CME to the file ESU20_FUT_CME.scid. Service: cme 2025-03-11 11:23:39.038 | HD Request # 5 | Download start date-time: 2020-09-18 08:29:59.000000. File last date-time: 2020-09-18 08:29:59.270000 2025-03-11 11:23:39.038 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149 2025-03-11 11:23:39.038 | Socket (3) | Creating socket. 2025-03-11 11:23:39.038 | Socket (3) | New receive buffer size: 0 2025-03-11 11:23:39.038 | Socket (3) | Connecting to IP: 67.214.125.3. 2025-03-11 11:23:39.094 | HD Request # 5 | Setting DTC encoding to Binary VLS 2025-03-11 11:23:39.094 | HD Request # 5 | Sending historical data logon request message. 2025-03-11 11:23:39.170 | HD Request # 5 | Requesting Intraday data. Start date-time: 2020-09-18 08:29:59. Record interval: 0. Symbol: ESU20 2025-03-11 11:23:39.194 | HD Request # 5 | Decompressing data. 2025-03-11 11:23:39.213 | HD Request # 5 | Receiving Intraday data for ESU20_FUT_CME starting at 2020-09-18 08:29:59.270000 2025-03-11 11:23:39.213 | Socket (3) | CloseSocket call. 2025-03-11 11:23:39.213 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-03-11 11:23:39.215 | Historical data download thread signaled to stop. 2025-03-11 11:23:39.215 | HD Request # 5 | Received 1 Intraday data record from 2020-09-18 08:29:59.270000 to 2020-09-18 08:29:59.270000 (0.0 seconds. Delay: 4.5 years) and wrote 0 records for ESU20_FUT_CME 2025-03-11 11:23:39.215 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2020-09-18 13:29:59.270000 2025-03-11 11:23:39.215 | HD Request # 5 | Completion time: 0s. 2025-03-11 11:23:39.215 | HD Request # 5 | Intraday data download complete for ESU20_FUT_CME. Unique request ID: 5 2025-03-11 11:23:39.215 | Removing historical data download ID 5. 2025-03-11 11:23:39.215 | Real-time Intraday chart data file updates started for ESU20_FUT_CME 2025-03-11 11:23:39.215 | Intraday chart data file opened for ESU20_FUT_CME 2025-03-11 11:23:39.215 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2025-03-11 11:23:39.215 | 2025-03-11 11:23:39.215 | Triggering next historical data download in queue. 2025-03-11 11:23:39.215 | HD Request # 6 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme 2025-03-11 11:23:39.215 | HD Request # 6 | Download start date-time: 2025-03-11 11:23:23.000000. File last date-time: 2025-03-11 11:23:23.865002 2025-03-11 11:23:39.215 | HD Request # 6 | Using server: ds26.sierracharts.com port 10150 2025-03-11 11:23:39.242 | Socket (3) | Socket gracefully closed by remote side. 2025-03-11 11:23:39.242 | Socket (3) | Closed. 2025-03-11 11:23:39.276 | Socket (4) | Creating socket. 2025-03-11 11:23:39.276 | Socket (4) | New receive buffer size: 0 2025-03-11 11:23:39.276 | Socket (4) | Connecting to IP: 64.152.155.17. 2025-03-11 11:23:39.321 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-03-11 11:23:39.321 | HD Request # 6 | Sending historical data logon request message. 2025-03-11 11:23:39.392 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-03-11 11:23:23. Record interval: 0. Symbol: ESH25 2025-03-11 11:23:39.413 | HD Request # 6 | Decompressing data. 2025-03-11 11:23:39.441 | HD Request # 6 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-03-11 11:23:23.026000 2025-03-11 11:23:39.442 | Socket (4) | CloseSocket call. 2025-03-11 11:23:39.442 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-03-11 11:23:39.442 | Historical data download thread signaled to stop. 2025-03-11 11:23:39.442 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-03-11 11:23:23.946000. 2025-03-11 11:23:39.443 | HD Request # 6 | Received 802 Intraday data records from 2025-03-11 11:23:23.026000 to 2025-03-11 11:23:39.202000 (16.2 seconds. Delay: 0.2 seconds) and wrote 694 records for ESH25_FUT_CME 2025-03-11 11:23:39.449 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-03-11 16:23:39.202000 2025-03-11 11:23:39.449 | HD Request # 6 | Completion time: 0s. 2025-03-11 11:23:39.449 | HD Request # 6 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 6 2025-03-11 11:23:39.449 | Removing historical data download ID 6. 2025-03-11 11:23:39.449 | Real-time Intraday chart data file updates started for ESH25_FUT_CME 2025-03-11 11:23:39.449 | Intraday chart data file opened for ESH25_FUT_CME 2025-03-11 11:23:39.449 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-03-11 11:23:39.449 | 2025-03-11 11:23:39.449 | No download requests in the queue to start downloads for. 2025-03-11 11:23:39.468 | Socket (4) | Socket gracefully closed by remote side. 2025-03-11 11:23:39.469 | Socket (4) | Closed. 2025-03-11 11:23:43.552 | Opened cached Intraday file: C:\SierraChart\Data\ESH25_FUT_CME.scid. Thread ID: 25432 |
[2025-03-11 16:26:59] |
MESSAGE LOG send for ESH25
[2025-03-11 16:39:22] |
There is nothing in the log that shows any issues. Do you have the Data Delay "DD:" showing in your Chart Header? If not, then please add it by following these instructions: Working With Charts: Region Data Line / Chart Header Then tell us (or take a screen image) of what you are seeing in the DD: entry. Refer to the following for how to take a screen image for us: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-11 17:44:46] |
I added DD and everytime I have looked at it, it's been 00:00:00. There are multiple prints every second in ESH, sometimes dozens. All I can tell you is that your prices lagged behind IB earlier this morning at multiple times. One time I believe was around 9:28 central time on a dip into 5571.00 and a bounce, if you can check what you were displaying vs. another data source. |
[2025-03-11 20:04:47] |
There was an issue at 2025-03-11 14:38 UTC time. That is the only issue we know of.
[2025-03-11 20:12:29] |
What do you mean by issue? Was there a lag in prices?
[2025-03-11 20:26:25] |
There was a connectivity issue, which would have resulted in a delay in the updates to your system at that time.
