Date/Time: Sat, 19 Apr 2025 15:21:50 +0000
VP Value Area and MP Value Area
View Count: 85
[2025-03-11 08:24:28]
VenoYoTiK - Posts: 19
The Weekly Market Profile Value Area and Volume Profile Value Area are identical.
Which Setting is causing this issue, because in my Daily Profile I do not have this Problem. So there must be some Setting which is causing this to occur.
Thank You very much! :)
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=117076
imageScreenshot 2025-03-11 at 09.19.28.png / V - Attached On 2025-03-11 08:24:06 UTC - Size: 657.27 KB - 27 views
[2025-03-11 14:40:23]
John - SC Support - Posts: 39362
By default, the Value Areas are calculated differently for the TPO and Volume Profiles. Refer to the following and the item below it:
Time Price Opportunity (TPO) Profile Charts: TPO Value Area
If you want the same calculation, then you need to set the TPO to perform a Volume Value Area calculation. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Value Area Highlight Based On Volume
