Date/Time: Fri, 20 Sep 2024 05:49:41 +0000
Studies not showing after Period change
View Count: 981
[2014-09-24 05:03:41] |
User19546 - Posts: 7 |
Changed Period from M5 to H1 and back to M5. Studies (MA's) are now not showing on the chart. They still exist in the studies list. I have restarted Sierra but still no visible studies. I have reapplied the Study collection but still no visible studies. What has happened and how do I fix it?? |
[2014-09-24 06:42:29] |
Based upon the length of those moving averages, you will need to increase the amount of days of data in the chart. Refer to help topic 42: Http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
