Date/Time: Sat, 19 Apr 2025 15:21:53 +0000
Wrong Limit price on EuroFX (6E)
View Count: 93
[2025-03-10 15:57:13] |
User682710 - Posts: 2 |
Hello, I recently wanted to try my setup on EuroFX (6E or M6E). I normally trade ES and everything is fine on this side. But the problem I have is when I try to put a sell limit order, for example at 1.09015 it actually put my limit at 10901.50 so it multiply it by a factor of 10000 (I can see my order on Rtraderpro). And I cannot take buy limit orders because it think the price is at 10000 so it automatically fill me market when I try. I tested on Ninjatrader and everything work fine so I don't think it's my data feed, and I also tried the method of "updating my symbol setting from server" and applying the "Global symbol settings" in "chart setting" but it change nothing. I noticed that when I change the "Real time price multiplier" my order change so I don't know if it's related or not. I put a screen shot of the price on Sierra chart the price on RtraderPro and my symbol settings. Thanks in advance for the help. |
[2025-03-10 17:02:55] |
Sierra_Chart Engineering - Posts: 19276 |
Definitely do not do this!: I noticed that when I change the "Real time price multiplier" my order change so I don't know if it's related or not. Refer to the information here to resolve this: Sierra Chart Teton Futures Order Routing: Using Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
