Date/Time: Sat, 19 Apr 2025 15:21:52 +0000
Is It Possible to Configure a Chart to Grow Instead of Prune?
View Count: 109
[2025-03-10 05:52:53] |
User413206 - Posts: 36 |
For example, if I start with 10 days of price data on a chart from 2/26/2025 to 3/10/2025, when 3/11/2025 arrives, I would like the chart to have 11 trading days of data starting from 2/26/2025 to 3/11/2025. When the next week arrives, I want to reset to 10 days of data and repeat the process. |
[2025-03-10 06:21:43] |
Sierra_Chart Engineering - Posts: 19276 |
Yes this is how charts normally work. They will continue to increase in length, until you reload them with Chart >> Reload and Recalculate or when you close and reopen the Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-10 06:49:37
[2025-03-10 16:51:41] |
Thanks that's good to know. My other platforms will truncate the chart to fit the window, which is annoying.
