Date/Time: Mon, 21 Apr 2025 04:38:31 +0000
[User Discussion] - Control bar - buttons to change the chart tick size?
View Count: 65
[2025-03-10 04:01:49]
fiinreea - Posts: 1
The tick setting I use for 1m to 5m footprint charts is 0.25, but for higher timeframes, like 30m+, I use 1.0 or 2.0 so the numbers are not so vertically squished. Is there a way to add chart tick size presets (0.25, 0.5, 1.0, 2.0, etc) to the control bar like there is for changing the time frame values (1m, 5m, 10m, etc...)? I don't like using the volume at price multiplier because it seems to move some values to the wrong places and it appears there is no option for this in the control bar customization.
Date Time Of Last Edit: 2025-03-10 04:15:29
[2025-03-10 06:51:46]
Sierra_Chart Engineering - Posts: 19285
You have to create a custom study to do this. Refer to:
ACSIL Interface Members - Variables and Arrays: sc.TickSize
And refer to:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
