Date/Time: Fri, 20 Sep 2024 06:52:07 +0000
Using Sierra Trading Platform for Equity Option trading.
View Count: 977
[2014-09-24 03:22:12] |
User22591 - Posts: 133 |
I am not sure I understand your respond to my question. I trade daily and would like to use your trading platform. Can your trading platform be use for option trading? If it can- may I have support from someone to showing me how to set it up and trade with it. Winston Date Time Of Last Edit: 2014-09-24 09:53:51
[2014-09-24 21:57:43] |
You can trade options, but the only practical way Sierra Chart will support this is by setting a chart or trade DOM to an option symbol. Since you are using Interactive Brokers, refer to the documentation here about option symbols: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Option Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-25 03:32:43] |
Now we are getting somewhere. I trade on the charts and I currently use your charts. What I need is some questions to be answered on the chart setting window and the trade window and Dom. You have given me the Equity Option Symbol format. Yours Winston |
