Date/Time: Mon, 21 Apr 2025 04:47:11 +0000
Replay Feature not working
View Count: 124
[2025-03-09 16:32:07] |
cjb111 - Posts: 18 |
Hello Support, My Replay feature suddenly stop working. I was doing back testing on a new strategy and probably reviewed about 5 or 6 different dates and about the same amount the previous day. Then it just stopped allowing me to back test. When I select a date and hit play, it will not go to that date, instead it stays at the present-day screen. Any idea on what could have cause it to just randomly stop working? Thank you Jermain |
[2025-03-09 19:15:46] |
Sierra_Chart Engineering - Posts: 19285 |
Follow the instructions here and do not use a specified Date-Time: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-09 19:20:41
[2025-03-09 21:27:17] |
Unfortunately the instructions for "Chart Replay Window Not Visible" didn't fix the problem. I tried both a specified Date-Time and with it. Any other possible solutions you can recommend I try? Jermain |
[2025-03-09 22:50:16] |
This is what we linked to: Replaying Charts: Basic Chart Replay Instructions Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
