Date/Time: Mon, 21 Apr 2025 04:38:25 +0000
Chart Not Updating to Current Date
View Count: 71
[2025-03-09 12:28:29]
User840659 - Posts: 1
I am experiencing an issue where my chart is only showing data up to February 7th. I've checked the chart settings, but I haven't been able to resolve the issue.
I Tried also with:
- right click --> delete and download data
- check that the future is the current
Also the payment of the data feed are ok
Thank you for your assistance.
Best regards
imagescreen d.jpg / V - Attached On 2025-03-09 12:25:34 UTC - Size: 104.01 KB - 21 views
[2025-03-09 18:57:41]
Sierra_Chart Engineering - Posts: 19285
You probably are not using the right symbol. Refer to:
Data/Trading Service Connection and Symbol Issues: 1.3. Symbols
If you are using the right symbol, then we need to see the log:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
After the connection and after about 60 seconds, provide a copy of the Message Log following these instructions:
Date Time Of Last Edit: 2025-03-09 18:58:10
