Date/Time: Mon, 21 Apr 2025 04:44:12 +0000
Drawing snap (magnet) to another drawing
View Count: 97
[2025-03-09 10:58:08] |
User918104 - Posts: 5 |
Hello ! I tried to find a way to drag a drawing and make it snap to another, for example a line to another line ? Also trying do draw a line and have the end snap to another drawing but couldnt find any way. I can successfully use the shift to snap to candlesticks highs/lows but i struggle with drawings when they are not touching a candle. Is there a way that can help me ? Thank you ! |
[2025-03-09 19:43:02] |
Sierra_Chart Engineering - Posts: 19285 |
There is no support for this. We do not think we have ever had anyone ever ask for this before. Here is the documentation for the snapping functionality that Sierra Chart has: Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-09 19:43:56
