Date/Time: Mon, 21 Apr 2025 04:50:12 +0000
Missing Labels column
View Count: 113
[2025-03-09 02:51:24] |
User779556 - Posts: 7 |
The Labels column at the right edge of my chart, next to the Price column, is missing. Nearly six lines of studies are identified by labels on this part of my primary chart. The study lines seem to be drawn but possibly not extended to the right edge making it hard to know what each for one is an indicator of. I don't think I did anything to turn it off, but I have searched for hours without success trying to find a way to retrieve it. Is that possible, or will I have to start from scratch and recreate the main chart and the other 5-supporting windows and DOM for that chart? Unfortunately, I don't have a backup of my futures ES trading chart. Would there be any way to duplicate a similar window from another chart window, match the ticker symbol, and attach it to the chart with the defective primary chart window? Need to know what I am up against! The chart is heavily formatted. Thanks for your help! Screenshot of MES is missing Labels column. Screenshot of MNQ is correct and attached for comparison. Both are 2 min. charts. |
[2025-03-09 20:03:29] |
Sierra_Chart Engineering - Posts: 19285 |
Make sure the Label Column is added: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) And there are backups of Chartbooks available: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-10 03:26:12] |
Thank you. THANK YOU. THANK YOU!!!
