Date/Time: Sat, 19 Apr 2025 15:21:51 +0000
Labels column is missing,
View Count: 114
[2025-03-08 20:57:39] |
User779556 - Posts: 7 |
The Labels column at the right edge of my chart, next to the Price column, is missing. Nearly six lines of studies are identified by labels on this part of my primary chart. The study lines seem to be drawn but possibly not extended to the right edge making it hard to know what each for one is an indicator of. I don't think I did anything to turn it off, but I have searched for hours without success trying to find a way to retrieve it. Is that possible, or will I have to start from scratch and recreate the main chart and the other 5-supporting windows and DOM for that chart? Unfortunately, I don't have a backup of my futures ES trading chart. Would there be any way to duplicate a similar window from another chart window, match the ticker symbol, and attach it to the chart with the defective primary chart window? Need to know what I am up against! The chart is heavily formatted. Thanks for your help! |
[2025-03-10 15:24:19] |
John - SC Support - Posts: 39362 |
Refer to the following for how to add a column to a DOM (including the "Label" column): Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-10 17:34:53] |
Thank you. Problem resolved.
