Date/Time: Mon, 21 Apr 2025 04:47:15 +0000
A way to sort trades by date/time
View Count: 126
[2025-03-08 18:18:39] |
User925540 - Posts: 62 |
In >Trade>Trade Activity Log>Trades
Is there a way to sort the trades by entry/exit date/time?I tried >Edit>Descending Display Order
But that still sorted them with the group of symbols.In other words, the entries in that table are always grouped by symbol so no matter how they get sorted the symbol is taken into consideration first. Is there a way to sort by date/time regardless of the symbol? |
[2025-03-08 18:21:56] |
user_xyz - Posts: 467 |
FWIW this is on my list of SC to-do / find a way to accomplish same.
[2025-03-09 19:26:27] |
Sierra_Chart Engineering - Posts: 19285 |
No, you have to save the data on the Trades tab into a text file that you can put it into a spreadsheet and do additional sorting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
