Date/Time: Fri, 20 Sep 2024 05:56:02 +0000
Quick Question
View Count: 1071
[2014-09-24 00:32:46] |
rwilliams1 - Posts: 346 |
Is there an indicator in SC that will show the historical bid/ask spread (the net difference between the two)? I'm using Amp/CQG and would like to see how large the spread has gotten throughout the trading period, but I don't see any indicator listed in the software that can achieve this. Any help is appreciated.
[2014-09-24 01:27:38] |
Yes. Make sure you have tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Add the Time and Sales Bid & Ask to the chart to see the historical bid and ask values. You can calculate the difference by using Study Subgraphs Difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-24 03:04:46] |
Thanks alot! I'll try that out.
[2014-09-24 06:42:55] |
No need to say thank you please.
