Date/Time: Mon, 21 Apr 2025 04:44:13 +0000
While using Market Depth Graph Chart is coming to see the leftmost part
View Count: 94
[2025-03-08 13:39:11]
User921883 - Posts: 3
Hi, I am using Market Depth Graph and on different timeframes, the chart is coming at 3 different locations which is making it difficult to look what has happened, I am pretty sure this can be fixed. I am attaching the Screenshots which will explain my issue better.
As you can see with three different timeframes position of the candle stick is shifting
for higher timeframe like 1hour it's at the left most part of the screen.
imageimage.png / V - Attached On 2025-03-08 13:37:49 UTC - Size: 169.07 KB - 18 views
imageimage.2png.png / V - Attached On 2025-03-08 13:37:56 UTC - Size: 205.51 KB - 16 views
imageimage3.png / V - Attached On 2025-03-08 13:38:03 UTC - Size: 252.05 KB - 18 views
[2025-03-08 16:51:44]
User431178 - Posts: 649
You need to adjust the fill space, currently you have it locked.
Working With Charts: Scrolling The Chart and Right Side Fill Space
