Date/Time: Mon, 21 Apr 2025 04:47:17 +0000
Custom Study Name Alignment
View Count: 94
[2025-03-08 06:49:39]
Gradient - Posts: 121
How can the study name of a custom study be aligned on the right edge instead of the left?
I'm aware that this can be done for subgraphs but haven't seen documentation for the actual study name and values.
[2025-03-10 15:02:40]
John - SC Support - Posts: 39362
We assume you are referring to the Study Name in the Region Header. In which case there is no option for how it is aligned, it is always to the left.
If you are referring to something else, then we need more information on exactly what you are referring to, and an image would be helpful.
