Date/Time: Mon, 21 Apr 2025 04:41:23 +0000
how can I display volume bars under main chart candles like in tradingview?
View Count: 118
[2025-03-08 05:17:48] |
gaoxxxx - Posts: 5 |
I want volume bars stay on the very bottom of main chart constantly, like it is in the tradingview. How can I do it?
[2025-03-08 21:03:05] |
cmet - Posts: 690 |
If you're just using the volume study, set chart region to 1 and scale settings to automatic zero based. See image. |
[2025-03-09 19:16:53] |
Sierra_Chart Engineering - Posts: 19285 |
Here are the instructions to add the Volume study: Chart Studies: Adding/Modifying Chart Studies Here is the documentation regarding Chart Scales: Chart Scale and Scale Adjusting Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-09 19:20:22
