Date/Time: Mon, 21 Apr 2025 04:38:26 +0000
Order entry: Multiple entries via 1-click bracket order (or similar)
View Count: 127
[2025-03-08 04:02:10] |
User265619 - Posts: 4 |
Please see attachment. Currently, as shown in the attached video, I can place a 1-click bracket order with a common stop and multiple targets. I would like the ability to add a secondary order using the same (or similarly configured) 1-click approach. The second entry would be at a fixed offset from my manual entry (e.g. -8 ticks), as is roughly shown at the end of the attached video. The end result would be: - 1-click - 2 entry orders <-- - 3 targets - 1 common stop Is this possible via Sierra? Thanks in advance. Date Time Of Last Edit: 2025-03-08 17:46:10
Private File |
[2025-03-10 14:49:25] |
John - SC Support - Posts: 39362 |
There is not a way to do this using the built-in tools. The only way to do this would be to create a custom study. Refer to the following: Automated Trading From an Advanced Custom Study https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
