Date/Time: Mon, 21 Apr 2025 04:44:11 +0000
OpenGL enabled vs disabled?
View Count: 149
[2025-03-07 23:11:41]
User932063 - Posts: 10
Do things visually look different if you have OpenGL enabled? Or does it just somehow speed up the charting experience?
I'm asking this because I am unable to turn it on via Windows 11/Parallels, so I didn't know how necessary it is.
Thank you!
[2025-03-07 23:39:29]
John - SC Support - Posts: 39362
There are some very small differences in how things look with OpenGL versus using the native Windows graphics. It is not something you would notice unless you knew specifically where to look (things like when a number is supposed to be "Bold").
The main difference is that with OpenGL graphics calculations are moved to the Graphics Processing Unit (GPU) which frees up calculations from the main processor, giving an overall boost to performance.
